Введение
This guide outlines how to remove the back panel of an HP Chromebook x360 14c-ca0053. The back panel functions to protect the interior of the Chromebook and provide structure, so it is susceptible to damage and may need to be replaced in time.
Выберете то, что вам нужно
Use tweezers to peel back the feet on the top and bottom of the Chromebook to reveal four additional screws.
Use a Phillips #1 screwdriver to remove the 4 7 mm screws located at each corner of the device under the grips.
Insert an opening pick between lower case and chassis.
Separate the lower case from the frame by sliding the opening pick along the perimeter until the case releases.
Еще один человек закончил это руководство.
