Введение
If the Bottom Shield of your HP Chromebox is damaged, it is easy to replace. This guide will take you through the steps of replacing the bottom shield. For this guide, you will need the Philips #1 screwdriver .
Выберете то, что вам нужно
Position the device upside-down on a flat, level surface with the USB ports facing you.
Using your Phillips head screwdriver, remove the four Phillips M2.5×4.0 screws that secure the bottom cover to the computer. In this step the usage of the magnetic mat will be helpful to keep up with the screws.
Insert the flat end of your metal spudger under the bottom cover near the USB ports, then pry the bottom cover off the computer.
Using your Phillips #1 screwdriver, remove the four Phillips M2.5×4.0 screws that hold the shield in place.
Insert your spudger into the gap between the bottom shield and the ports and gently pry to lift and remove the shield.
