HP Chromebox J5N50UT WLAN Module Replacement
Выберете то, что вам нужно
  1. HP Chromebox J5N50UT WLAN Module Replacement, Bottom Cover: шаг 1, изображение 1 из 1
    • Before removing the bottom cover, ensure that your computer is powered down and ensure that all external devices are disconnected. If you are unsure whether the computer is off or in hibernation mode, turn the computer on, then shut it down through the operating system.
    • Position the device upside-down on a flat, level surface with the USB ports facing you.
  2. HP Chromebox J5N50UT WLAN Module Replacement: шаг 2, изображение 1 из 1
    • Using your metal spudger, lift and remove the 4 rubber “feet” from each corner.
  3. HP Chromebox J5N50UT WLAN Module Replacement: шаг 3, изображение 1 из 1
    • Using your Phillips head screwdriver, remove the four Phillips M2.5×4.0 screws that secure the bottom cover to the computer. In this step the usage of the magnetic mat will be helpful to keep up with the screws.
  4. HP Chromebox J5N50UT WLAN Module Replacement: шаг 4, изображение 1 из 1
    • Insert the flat end of your metal spudger under the bottom cover near the USB ports, then pry the bottom cover off the computer.
  5. HP Chromebox J5N50UT WLAN Module Replacement, Bottom Shield: шаг 5, изображение 1 из 1
    • Lift the two pieces of mylar tape from the bracket.
  6. HP Chromebox J5N50UT WLAN Module Replacement: шаг 6, изображение 1 из 1
    • Using your Phillips #1 screwdriver, remove the four Phillips M2.5×4.0 screws that hold the shield in place.
  7. HP Chromebox J5N50UT WLAN Module Replacement: шаг 7, изображение 1 из 1
    • Insert your spudger into the gap between the bottom shield and the ports and gently pry to lift and remove the shield.
  8. HP Chromebox J5N50UT WLAN Module Replacement, WLAN Module: шаг 8, изображение 1 из 2 HP Chromebox J5N50UT WLAN Module Replacement, WLAN Module: шаг 8, изображение 2 из 2
    • Disconnect the white and black antenna cables from the module.
  9. HP Chromebox J5N50UT WLAN Module Replacement: шаг 9, изображение 1 из 3 HP Chromebox J5N50UT WLAN Module Replacement: шаг 9, изображение 2 из 3 HP Chromebox J5N50UT WLAN Module Replacement: шаг 9, изображение 3 из 3
    • Using your Phillips #1 screwdriver, remove the M2.0×3.0 screw from the upper left corner of the module.
    • Once the screw has been removed, the module will tilt up.
  10. HP Chromebox J5N50UT WLAN Module Replacement: шаг 10, изображение 1 из 2 HP Chromebox J5N50UT WLAN Module Replacement: шаг 10, изображение 2 из 2
    • Remove the WLAN module by pulling it away from the slot at an angle.
Заключение
Ashley Marvin
Участник с: 09/06/18
685 Репутация
Автор 5 руководств
Команда
Ohio State, Team S1-G3, Whitney Fall 2018 Участник Ohio State, Team S1-G3, Whitney Fall 2018
OSU-WHITNEY-F18S1G3
2 членов
Автор 5 руководств
Один комментарий
Please indicate brand/model/type of WLAN card, so we can know if we’re replacing with same/better upgrade.
When Ze - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 409
