Введение
If your printer is improperly taking in your paper through the bottom tray, you may need to replace your rollers. With nothing but a #2 Phillips screwdriver, you will be able to quickly remove them.
Выберете то, что вам нужно
Remove the bottom tray by pulling it until it fully is out of the printer.
Push on the exposed piece of rod that pokes out of one end of the roller.
Pull out the now unscrewed and free rod.
Use your thumb to push in the white plastic hanging over the roller and use your index finger to pry the roller out.
7 участников успешно повторили данное руководство.
Один комментарий
Thank you!
Should the black roller just behind these two rollers also be replaced?
Best wishes
Mark
