Введение
This guide will show step-by-step instructions to replace the bluetooth adapter in the HP Compaq 2510p. .
Выберете то, что вам нужно
Place the laptop upside down, with the battery facing away from you. Towards the bottom-middle of the laptop, you should see a small panel with a Bluetooth symbol.
There is 1 screw on the panel you located in step one. Use your Philips head screwdriver to remove the single screw.
Pull the adapter to the left exposing its underside. Locate and remove its only screw using your Phillip's head screwdriver.
Remove the adapter by pulling on the base of the connecting wires and the adapter, in opposite directions.
3 участников успешно повторили данное руководство.
