Введение
How to remove and replace WiFi card in the HP Compaq 2510p.
Выберете то, что вам нужно
Flip the laptop over and locate the RAM cover plate towards the left of the laptop. There will be two screws located on the panel.
Locate the screws at the top of the card and use your Philips screwdriver to remove them.
Lift the card from underneath the top, using the spudger to leverage the card upwards. Then pull to release the card.
Pull on each of the wires connected to the card. They will easily pop off and the WiFi card will be released.
Еще один человек закончил это руководство.
