Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Removing the wireless card takes some focus but it isn't very difficult. The only tool needed for this replacement guide is the PH00 bit. Don't worry about losing the first two screws that get unscrewed because they are attached to the device for your convenience. The two 0.4 cm screws are not attached to the device so make sure to put them in a safe place. Make sure the device is off before starting this guide. The Hard Drive Replacement Guide is a prerequisite to this guide so be familiar with that guide before beginning.
Выберете то, что вам нужно
Flip the laptop over to the backside. The Hard Drive is located on the bottom left.
Slide the hard drive case off in a horizontal motion away from the device to remove the hard drive.
The wireless card is located on the bottom of the laptop, however the hard drive case must be removed in order to access the wireless card.
Gently remove the black and white wires that are connected to the wireless card.
