Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Flip the laptop over to the backside. The Hard Drive is located on the bottom left.
Unscrew the two screws with a PH00 bit. This releases the hard drive.
Slide the hard drive case off in a horizontal motion away from the device to remove the hard drive.
The wireless card is located on the bottom of the laptop, however the hard drive case must be removed in order to access the wireless card.
Unscrew the two screws holding the hard drive in place, using a PH00 bit.
Slide the wireless card backing towards you to remove it from the laptop.
Gently remove the black and white wires that are connected to the wireless card.
