Введение
To remove the touchpad, you must remove other components to get to it such as the keyboard.
Выберете то, что вам нужно
Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
Locate the twenty 3 mm Phillips head screws.
Unscrew them using the PH0 screwdriver.
Unhook the two wires connecting to the wireless card by gently pulling them out.
Инструмент, используемый на этом этапе:Tweezers$4.99
Locate the power button connector wire.
Using the tweezers, unhook the wire.
Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
Locate the four 3 mm Phillips head screws.
Locate the disk drive on the side of the device.
Remove it by pulling it all the way out.
Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
Use the PH0 screwdriver to remove the six 1 mm Phillips head screws surrounding the touchpad
Use the plastic opening tool to pry up the touchpad cover.
Lift and remove the touchpad cover.
Use the blow dryer to melt the adhesive around the edge of the touchpad.
The touchpad is now free to be removed.
Еще один человек закончил это руководство.
