Введение
This guide will detail the steps of replacing a faulty CD Drive.
Выберете то, что вам нужно
Loosen the two indicated screws on the panel using a Phillips screwdriver with a PH1 head size.
Use plastic opening tools to lift up the hard drive. Set aside the hard drive without disconnecting the wire.
Use a Phillips screwdriver with a PH0 head type to unscrew the indicated 5.5mm screw.
Еще один человек закончил это руководство.
