Введение
Use this guide to replace the RAM stick. If your computer freezes up momentarily while running several programs, this may be the guide for you.
Выберете то, что вам нужно
Ensure the laptop is unplugged and completely powered off. Loosen the three small screws using a #1 Phillips screwdriver.
Carefully pry the panel up using a plastic opening tool.
Pull the panel away from the laptop and set it off to the side.
2 участников успешно повторили данное руководство.
