Введение
This guide will instruct users on how to successfully eject and replace the CD/DVD ROM drive.
Выберете то, что вам нужно
Make sure the laptop is powered OFF. Gently turn the laptop over and place it on a flat surface.
Locate the battery EJECT latch.
Grab the laptop firmly on the side and using your thumb, press the eject latch towards the OUTER edge of the device.
The battery will be lifted out of the laptop slightly as you press the latch over as far as it will go.
Pull the battery up and towards you to remove it from the laptop chassis.
Once the battery is out, you will be able to check the battery label for the replacement part number.
Locate the CD/DVD ROM drive. In order to recover an important disc from the drive, locate the manual release hole.
Insert paper clip or other small diameter object to engage the release mechanism.
Locate the screw that secure the CD/DVD ROM drive.
Use Philips #0 screwdriver to remove the 2.5 x 5.0mm CD/DVD ROM screw.
Еще один человек закончил это руководство.
