Введение
This guide will take you through the process of replacing the optical drive in a HP Compaq nc6400 Laptop. You will need the correct replacement optical drive for your laptop to complete the installation.
Выберете то, что вам нужно
Locate the battery lock below the battery labeled one.
Slide the lock all the way to the left to release the left lock of the battery.
Locate the lock labeled two at the bottom right corner below the battery.
Slide and hold the lock to the left.
Remove the 4 mm P0 Phillips-head screw indicated by the icon of a lock and disk.
Press and release the eject icon to partially eject the optical drive.
Use of a spudger may be necessary to pry open the optical drive.
2 участников успешно повторили данное руководство.
