Введение
Install the ink cartridge(s) when the printer runs out of ink or when the ink warning lights flash to prevent running out.
Выберете то, что вам нужно
Place your index finger in the opening on the front of the printer (right side below scanner/copier) and pull the door down.
Pull down on the tab that lies in the middle of the newly-exposed gray cover.
Grab the cartridge from the top and bottom and pull down until it clicks.
Pull out the freed cartridge.
Take the replacement cartridge out of its packaging and pull off the plastic tab.
Slide the cartridge directly into open slot (tri-color on the left, black on the right).
Push it forward until you hear it snap.
Open up the scanner lid and place the alignment page face-down in the right-front corner of the glass.
Close the lid.
When the power button stops blinking, your can now use your printer.
4 участников успешно повторили данное руководство.
