Введение
If you are having difficulties scanning or your scanner glass is broken, use this replacement guide to resolve the issue. The scanner glass is used to scan or copy pages.
Выберете то, что вам нужно
Unplug all cords from the printer, and remove all the paper from the tray.
Remove the four screws securing the scanner bed module to the printer body with a Torx T5 screwdriver.
Lift up the scanner bed module and remove the two ribbon cables by pulling them straight out.
Set the printer body aside.
Separate the plastic halves of the scanner bed by gently pulling the tabs on the clips holding the halves together.
Remove the glass pane from the plastic shell by prying the tabs back that secure the glass, as well as peeling the adhesive apart slowly.
Еще один человек закончил это руководство.
