Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If there are communication problems between the computer and printer, replacing the motherboard is an option to consider in order to fix this problem. The motherboard controls all operations and functions of the printer enabling it to run properly and communicate with the computer.
Выберете то, что вам нужно
Open the front access panel by placing your finger in the front slot and pulling gently.
Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
Carefully lift the top panel off of the printer.
Do not tear or damage the two cables that connect the top lid to the motherboard.
Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
Remove all of the wires connected to the mother board. There are seven in total.
Remove the three 9mm T10 Torx screws that hold the motherboard to the body of the printer
At this point, the mother board should be free of all connections from the rest of the printer.
Remove and replace the mother board with the new one.
7 участников успешно повторили данное руководство.
3 Комментариев
ok so ineed to replace the Motherboard -- where do I get this board and what is the cost?
ou est localiser le sensor encoder module cb781-8006 merci
ou est installer le sensor encoder CB781-8006 Merci
