Введение
Gear allows the scanner arm to follow the grain track and scan the document. Before replacing the gear make sure the printer is unplugged.
Запчасти
Детали не указаны.
  1. Unscrew and remove the center 13mm T10 Torx Security screw using the iFixit screwdriver Unscrew and remove the top right 13mm T10 Torx Security screw using the iFixit screwdriver Unscrew and remove the bottom left 13mm T10 Torx Security screw using the iFixit screwdriver
    • Unscrew and remove the center 13mm T10 Torx Security screw using the iFixit screwdriver
    • Unscrew and remove the top right 13mm T10 Torx Security screw using the iFixit screwdriver
    • Unscrew and remove the bottom left 13mm T10 Torx Security screw using the iFixit screwdriver
  2. Unscrew and remove the bottom 13mm TR10 Torx Security screws using the iFixit screwdriver Unscrew and remove the bottom 13mm TR10 Torx Security screws using the iFixit screwdriver Unscrew and remove the bottom 13mm TR10 Torx Security screws using the iFixit screwdriver
    • Unscrew and remove the bottom 13mm TR10 Torx Security screws using the iFixit screwdriver
  3. Unscrew and remove the top right13mm TR10 Torx Security screws using the iFixit screwdriver Unscrew and remove the top right13mm TR10 Torx Security screws using the iFixit screwdriver Unscrew and remove the top right13mm TR10 Torx Security screws using the iFixit screwdriver
    • Unscrew and remove the top right13mm TR10 Torx Security screws using the iFixit screwdriver
  4. Unscrew and remove the upper 13mm TR10 Torx  Security screw using the iFixit screwdriver Unscrew and remove the upper 13mm TR10 Torx  Security screw using the iFixit screwdriver
    • Unscrew and remove the upper 13mm TR10 Torx Security screw using the iFixit screwdriver
  5. Remove the scanner lid and plate (top cover). Locate the Scanner Arm Actuator.
    • Remove the scanner lid and plate (top cover).
    • Locate the Scanner Arm Actuator.
  6. Locate the Scanner Arm Accuator and remove. Locate the Scanner Arm Accuator and remove.
    • Locate the Scanner Arm Accuator and remove.
  7. Unscrew and remove the 13mm TR10 Torx  Security screw in the center of the gear using the iFixit screwdriver Unscrew and remove the 13mm TR10 Torx  Security screw in the center of the gear using the iFixit screwdriver
    • Unscrew and remove the 13mm TR10 Torx Security screw in the center of the gear using the iFixit screwdriver
  8. Locate the white gear and remove. Locate the white gear and remove. Locate the white gear and remove.
    • Locate the white gear and remove.
Заключение
Еще один человек закончил это руководство.
Elizabeth Surface
Участник с: 26.08.2015
1 441 Репутация
Автор 9 руководств
Команда
USF Tampa, Team 4-6, Meier Fall 2015 Участник USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 членов
Автор 14 руководств
Один комментарий
It is not possible to get to the bottom two screws out without tilting the scan bed/cover back more. To that, I had to disconnect the swing arm on the right side of the scanner bed/cover. After that, all worked smoothly. Thank you.
Ron - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 48
За всё время: 1,223
