Введение
AC Adapters control the flow of electricity from the outlet to your device. Over time, they may fail. Ensure you have unplugged your device before you begin this repair.
Выберете то, что вам нужно
Open the the printer by lifting the top section. Make sure you're lifting from the lowest portion of the scanner section.
Locate 13mm TR10 Torx Security screw behind screen and remove using Torx screwdriver.
Disconnect the wires from the AC adaptor.
Replace AC Adapter box. Reverse order of instructions for reassembly.
3 участников успешно повторили данное руководство.
