Введение
Removing the battery from the device is tricky because of the amount of wires attached to it and surrounding it. We did our best to take pictures showing how the wires are arranged and the best method for untangling them however it really just takes some time and care. Start by unplugging all the wires you can and then try to untangle them from the battery for best results. Good luck!
Выберете то, что вам нужно
Remove the SD card in the bottom of the computer by pressing the SD card in, and it will pop out.
Pull out the SD card completely and set aside.
Remove the two rubber screw covers on the bottom of the plastic cover using the plastic opening tool.
Unscrew the two 6.35 mm PH#1 screws that were underneath the rubber covers.
Use the plastic opening tool along the outer rim of the bottom portion of the back panel.
Take off this portion.
Remove three 6.35 mm screw from the back panel using a PH#2 or J1 screw driver.
Unscrew the two 6.35 mm PH#2 screws. They aren't able to be completely removed and will just be loosened similar to step 3.
Release the stand by pressing the large button on the left so that it is easier to take the back case off.
Use the plastic opening tool to separate the silver back cover from the screen body.
As shown in picture two, use the tool around the stand as well to avoid cracking the cover.
Slowly apply pressure to the outsides of the cover until it pops out of place.
Carefully lift the cover away from the computer and untangle it from the stand.
Disconnect the battery by using a plastic opening tool and taking the cable connection out.
Remove the two black 6.35mm PH #0 screws with a screwdriver from the top of the hard drive.
Remove the two silver 6.35mm PH#0 screws from the bottom of the hard drive.
Release the stand by pushing the grey lever in towards the screen.
Remove the fourteen 6.35 mm PH#0 screws around the stand recess and metal cage.
Gently remove wires from around the stand recess with the plastic opening tool.
Remove the stand recess by moving it towards yourself, rotating it about the hinge and then taking it out of the computer.
Remove the four 6.35 mm PH#0 screws from around the battery using the J1 screwdriver.
Disconnect the power button connector cable.
Disconnect the cable connection that's wrapped around the battery.
Gently remove the battery from the computer, making sure not to tug on any of the cables or wires during the removal.
9 участников успешно повторили данное руководство.
Один комментарий
Excellent Guide to use for this All in One, I enjoyed Finding and Using it
