Введение
If your laptops Fingerprint Scanner is damaged or no longer functioning reliably, use this guide to remove and replace it.
Выберете то, что вам нужно
Flip the device over so the base is facing the ceiling.
Lift up the tablet stand.
Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
Flip the tablet over with the screen facing upwards.
Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
Use the Phillips #00 screwdriver to remove the six 2 mm screws.
Gently disconnect the two connectors.
Disconnect the connector from the motherboard with your fingers.
Remove the two speaker/antenna module mounting 2mm screws using a Phillips #00 Screwdriver.
Use a spudger to gently pry the left black plastic speaker/antenna module off of the frame as pictured. Start by lifting up the right side of the module, then slowly work your way down the module towards the right.
Remove the 2mm bracket mounting screw from the frame using a Phillips #00 Screwdriver.
Lift up the bracket and set aside.
Инструмент, используемый на этом этапе:Tweezers$4.99
Open the ribbon cable clamp and pull the cable out.
Lift out the fingerprint scanner.
