HP Elite X2 1013 G3 Solid State Drive Replacement
Выберете то, что вам нужно
  1. HP Elite X2 1013 G3 Solid State Drive Replacement, Screen: шаг 1, изображение 1 из 1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Solid State Drive Replacement: шаг 2, изображение 1 из 2 HP Elite X2 1013 G3 Solid State Drive Replacement: шаг 2, изображение 2 из 2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Solid State Drive Replacement: шаг 3, изображение 1 из 2 HP Elite X2 1013 G3 Solid State Drive Replacement: шаг 3, изображение 2 из 2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Solid State Drive Replacement: шаг 4, изображение 1 из 2 HP Elite X2 1013 G3 Solid State Drive Replacement: шаг 4, изображение 2 из 2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Solid State Drive Replacement, Battery: шаг 5, изображение 1 из 1
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Solid State Drive Replacement: шаг 6, изображение 1 из 1
    • Lift the battery out of the housing.
  7. HP Elite X2 1013 G3 Solid State Drive Replacement, Solid State Drive: шаг 7, изображение 1 из 1
    • Make sure the device is powered off and the battery is removed before continuing!
    • Using the Phillips #00 Screwdriver, remove the single indicated screw.
  8. HP Elite X2 1013 G3 Solid State Drive Replacement: шаг 8, изображение 1 из 1
    • Gently tilt the drive upward, then firmly pull it out from the motherboard.
    • Pay attention to the orientation of the SSD. Trying to put your replacement SSD in the wrong way could damage the part or the connector.
Заключение
Еще один человек закончил это руководство.
Kory Haydon
Участник с: 04/18/19
259 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S9-G12, Maness Spring 2019 Участник Cal Poly, Team S9-G12, Maness Spring 2019
CPSU-MANESS-S19S9G12
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 13
За последние 30 дней: 75
За всё время: 2,731
