Введение
The front-facing camera is an important of any modern tablet or laptop . This guide shows how to replace a broken or malfunctioning webcam on the HP Elite x2 1012 G2.
Выберете то, что вам нужно
Turn the device over so the screen is facing you.
Place a suction cup firmly onto a corner of the screen.
Lift up gently until you see the screen separate from the casing.
Repeat this process for all four corners.
Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
Remove the wire connector to the front webcam using a plastic opening tool. Hook the tool underneath the connector and pull up and back.
Remove the connector immediately to the left of the front webcam's connector. Use a plastic opening tool to gently lift the connector up and out.
Remove the connector immediately to the right of the front webcam's connector. Use a plastic opening tool to gently lift the connector up and out.
Use a Phillips screwdriver to remove the Phillips M2.0x2.0 screw to the left of the webcam. Turn the screwdriver counterclockwise to remove the screw.
2 участников успешно повторили данное руководство.
