Выберете то, что вам нужно
Turn the device over so the screen is facing you.
Place a suction cup firmly onto a corner of the screen.
Lift up gently until you see the screen separate from the casing.
Repeat this process for all four corners.
Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
Remove the antennae connections from both the WiFi card and the wireless cellular M.2 card.
Gently pull the black and red wire free at the motherboard connector.
On the right speaker, the black antena piece must be removed before the speaker can be accessed.
Now remove the green and white wires from the cable management track and the speakers will be completely removed from the device.
Еще один человек закончил это руководство.
