Введение
Use this guide to replace and / or adjust the screen of the HP Elite x2 G1.
Запчасти
Никакие детали не требуются.
  1. With the screen face down, lift up the stand as far as it goes.
    • With the screen face down, lift up the stand as far as it goes.
    • Make sure not to force it past the resting point.
  2. Use a screwdriver to remove the six screws on the back of the tablet. (The screws were not in our device, so we do not know what kind of screwdriver to use.)
    • Use a screwdriver to remove the six screws on the back of the tablet.
    • (The screws were not in our device, so we do not know what kind of screwdriver to use.)
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. After removing the screws, delicately close the stand.
    • After removing the screws, delicately close the stand.
    • Flip the tablet on its back so that the screen is facing up.
  5. Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion. Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
    • Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
    • Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
  6. Remove the tape on the lower left side of the screen. Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen. Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
    • Remove the tape on the lower left side of the screen.
    • Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
  7. Disconnect the flex cable from the device using the spudger. Remove the Display Assembly from the device.
    • Disconnect the flex cable from the device using the spudger.
    • Remove the Display Assembly from the device.
Заключение
Colin Mika
Участник с: 19.04.2018
773 Репутация
Автор 6 руководств
Команда
Cal Poly, Team S24-G7, Maness Spring 2018 Member of Cal Poly, Team S24-G7, Maness Spring 2018
CPSU-MANESS-S18S24G7
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 4
За 7 дней: 12
За 30 дней: 61
За всё время: 435
