Введение
If the tablet experiences one of the three symptoms below, there might be a problem with the motherboard.
- The initial start-up functions appear like indicative light, fan, and hard drive sound, but disappears after a while, i.e., 5 – 3 minutes.
- A high pitched sound comes from the laptop when you press the “on” button.
- Your screen is projecting a black screen, even though all other components such as fans, indication light and hard drive seems to be working perfectly.
Before going through the replacement process, make sure your tablet is turned off and not connected to the power cord.
Выберете то, что вам нужно
While the screen is facing down, remove six 3.0 mm Torx T5 screws under the stand.
Detach the WWAN card from the motherboard by pulling it to the left using tweezers.
3 участников успешно повторили данное руководство.
Один комментарий
¿basta con esto para cambiar el cable LCD?
Is this enough to replace the LCD wire?
