Введение
This guide is useful if the keys on the device’s keyboard are malfunctioning or broken. This guide will show you how to replace broken keys, and also offer a couple troubleshooting tips if the keys are simply malfunctioning, or if the keys are “sticky.” The only tool you need for this guide is a spudger, but you could also use a toothpick or a dampened q-tip if you are trying to fix malfunctioning or “sticky” keys.
Выберете то, что вам нужно
Wedge the spudger under the corner of the key and pry up while moving the spudger along the length of one edge of the key.
Repeat this process for three sides of the key you are removing.
Lift the key manually by the the edge opposite the one side of the key you did not pry off with the spudger.
To replace the key, lay the new key over its housing with the proper orientation and push it down until you hear a click.
