Введение
This guide will assist you in replacing the speakers on your HP EliteBook 1050 G1. If there is a change in quality of sound or possibly no sound at all coming from the speakers on your laptop then this guide will be useful for you.
For this replacement guide you will need a Phillips #00 Screwdriver, iFixit opening tool, Spudger, and the TR9 Torx Security Screwdriver.
Выберете то, что вам нужно
Close your laptop and turn it over so that the side without the HP logo is facing you.
Using the TR9 screwdriver, loosen the nine screws from the base of the device.
Remove the base by inserting the plastic opening tool into the slit between the two portions of the case and gently prying the metal cover away from the body of the device.
Slowly work your way around the edge of the base.
Lift the cover of the laptop off of the body of the device.
Find the connector between the battery and the device. It is on the left-hand side above the battery.
Use the spudger to gently pull the corners of the connector away from the black housing.
Remove the seven black 3mm Phillips #00 screws next to the M2x3 label along the edge of the battery using the Phillips #00 screwdriver.
Use the spudger to wiggle out the speaker cable. Make sure to apply moderate pressure on the sides as this will make it easier for the speaker cable to come out.
Remove the cable from the spongy connector by sliding it out.
Let the cable rest on the bottom of the motherboard so it doesn't get in the way.
Using a Phillips #00 Screwdriver, unscrew the two 3 mm silver screws from the speaker.
Use the iFixit opening tool to remove the speaker cable for the other speaker. Make sure to apply moderate pressure on the sides of the cable to loosen it.
Use the Philips #00 screwdriver to remove the two 3 mm silver screws on the speaker.
