Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Type CMD in the Start Menu and open Command Prompt.
Type the following command to view memory details and press Enter.
Power off the Notebook.
Select the Start button.
Select the Power button.
Select Shut down.
Disconnect the power adapter.
Инструмент, используемый на этом этапе:Plastic Cards$2.99-
Turn the notebook upside down on a flat surface.
Loosen the six captive screws and the two inset captive screws counter-clockwise with the Phillips #00 screwdriver.
Pry the bottom cover with plastic card or spudger at the bottom right corner.
Lift the bottom cover off with plastic card.
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95-
Pull the battery cable from the system board.
Spread the retaining tabs on each side of the memory module slot to release the memory module.
Pull the memory module away from the slot at an angle.
Insert the memory module into the slot at an angle.
Push down the center of memory module until the retaining tabs lock the RAM stick.
Push down the bottom cover at the four corner and center.
Tighten the six captive screws and the two inset captive screws clockwise with Phillips #00 screwdriver.
wmic memorychip get devicelocator, manufacturer, partnumber, serialnumber, capacity, speed, memorytype, formfactor
Right-click on the taskbar.
Select the “Task Manager”.
Select the "Performance".
Еще один человек закончил это руководство.
