Введение
Identifier, remplacer ou ajouter une barrette de mémoire (RAM)
Identify, replace or add a memory (RAM)
Выберете то, что вам нужно
Spread the spring blades that hold the memory strip in place (left and right).
With your finger, gently remove the memory module (RAM).
Place the new memory module (RAM) in its slot.
Option: add a second memory module (RAM).
Gently press the top of the memory module until the spring blades engage (clicks!).
Repeat same procedure as for the first RAM module.
