Введение
This guide will show you how to replace the display assembly for an HP EliteBook 840 G7
To know if you have a bad screen signs include: Large crack in screen, no response, dim light, large rainbow lines and dots.
Выберете то, что вам нужно
Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
Remove the connector that connects the battery to the motherboard.
Once you've disconnected all cables from their sockets, gently move them to the top of the laptop.
Open the laptop to a 90 degree angle.
Slide the display hinges away to remove the display assembly.
Еще один человек закончил это руководство.
