Введение
Use this guide to replace the keyboard on a HP EliteBook 840 G7
Выберете то, что вам нужно
Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
Remove the connector that connects the battery to the motherboard.
Once you've disconnected all cables from their sockets, gently move them to the top of the laptop.
Open the laptop to a 90 degree angle.
Slide the display hinges away to remove the display assembly.
Pull on the bundled connector to remove.
Remove the speaker system from the board.
Push away to remove the bundled connector from its port.
Move the cable away from the ZIF connector below.
Use your Phillips #1 screwdriver to remove the three 1.3 mm screws.
Lift up and away to remove the USB ports.
Use your Phillips # 1 screwdriver to remove the three 1.2 mm screws that hold the fan in place.
Lift up from the left side of the fan then pull towards you to remove.
After removing the connector pull off the CMOS battery.
Use your Phillips #1 screwdriver to remove the single 1.2 mm screw.
Pull on the cable to remove the charging port.
Release the latch on the ZIF connector.
Carefully pull the connector to remove.
Use you Phillips #1 screwdriver to remove the eight 1.2 mm screws.
Lift the whole board up to remove.
Use your Phillips #000 screwdriver to remove the four 1 mm screws.
Pull up to remove.
Use your Phillips #000 screwdriver to remove the five 1 mm screws.
Lift the touchpad to remove.
5 участников успешно повторили данное руководство.
3 Комментариев
the keyboard is part of the top shell and is rivetted in, you need to replace the whole part
