Введение
Are keys on your HP EliteBook 8440p laptop keyboard broken, stuck, or dirty? It might be time to replace your keyboard, and this guide will teach you how to do it yourself! Removing the keyboard is also a crucial step to getting inside the computer to make repairs or clean.
Выберете то, что вам нужно
With a Phillips-head screwdriver, unscrew the three screws marked with the keyboard icon.
Turn the laptop over and open the cover.
Push down the little clips located between the Function Keys to release the top of the keyboard. Lift the keyboard gently with a forward and upward motion.
Rest the keyboard over the touch pad.
Using a spudger or flat-head screwdriver, pull up the tabs at the black ribbon cable's sides to unlock the cable.
Using a spudger or flat-head screwdriver, pull up the tabs at the white ribbon cable's sides to unlock the cable.
21 участников успешно повторили данное руководство.
5 Комментариев
The top of the keyboard has locking tabs that need to be pulled back towards the keyboard center or it won't come out. They hold the replacement keyboard in place long enough to get the screws into it.
But you don’t need to remove the battery.
Perfect guide except for keyboard tabs mentioned in comment from Robert Taylor! Well done!
PERFECT! It took me 15 minutes to replace the keyboard!
