Введение
The fan in this laptop ensures that all the components are at a temperature where they can perform to the user’s standards. It is located inside the laptop in the upper left corner.
A fan that is damaged or broken could lead to overheating and a loss of performance in the laptop. Things to look for are your keyboard feeling warm, the laptop freezing for no apparent reason, and a lack of air dispersed from the laptop's exhaust ports.
This step should be completed after removing the battery and service cover from the underside of the computer.
Выберете то, что вам нужно
Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
Slide the battery latch positioned to the right over to the right side. Hold it there.
With the laptop latch still facing away from you, slide the left release latch to the left.
Slide the door away from you, toward the opening latch.
Lift the door upwards away from the computer.
Remove the 5 mm Phillips #00screws to the bottom-left of the fan.
Remove the captive screw positioned to the top-right of the fan with a Phillips #00 screwdriver.
Lift the right side of the fan and slide it out from below the edge of the case.
Lift up on the fan and remove.
Еще один человек закончил это руководство.
