Выберете то, что вам нужно
Unscrew the 5 marked captive screws with a Phillips #1 and flip the device so the hinge is faced towards you
Slide a spudger under the shell to pop the clips and run it around the perimeter of the shell until you can remove it.
Lift directly up on the marked tab to remove the shielding
The RAM is now exposed.
The new RAM can be inserted and clipped down as shown.
For reference the 850 G7 uses DDR4 SODIMMs
