Введение
This is a guide that will show you how to replace the battery of an HP EliteBook 8530w.
The battery of a laptop is the most common thing that needs replacing. Luckily, it is the easiest thing to replace for this laptop.
Turn the laptop off then place it down so that the back is facing up.
Slide the battery release switch to the left and hold it there.
Pull the battery away upward and away from the laptop while continuing to hold the release switch.
