Введение
RAM (Random Access Memory) is the laptop’s system storage. It is used to handle short-term data storage while being fast sending and receiving it. Upgrading RAM to faster and/or higher capacity ones can improve system responsiveness and/or allow more programs to be ran at the same time. Use this guide to replace the RAM in your HP EliteBook 8530w.
Выберете то, что вам нужно
Turn the laptop off then place it down so that the back is facing up.
Slide the battery release switch to the left and hold it there.
Pull the battery away upward and away from the laptop while continuing to hold the release switch.
Unscrew the two screws with a RAM/WiFi icon using a Phillips #00 screwdriver.
After the screws are loosened, pull the cover off by lifting up from the side with the screws.
Pull the RAM out of the laptop in the direction the RAM is pointing at to remove it.
Один комментарий
I just removed my 2G ram from the back as soy said but the laptop still can run.
At the slot of the ram I removed it has a number 3 and I am wondering if it is a "hidden" one?
