Введение
There are many reasons why you might need to replace a hard drive, including hardware failure, corruption, or insufficient space. These issues can lead to lags, blue screens, file loss, frozen programs, and other symptoms on your device. This guide demonstrates how to replace the hard drive on an HP EliteBook 8560p.
Be aware that when replacing a hard drive, you may or may not need to reinstall your operating system. Before you begin, backup any important documents or files in case of any issues during the repair. Turn off your laptop and unplug it from the charger.
Выберете то, что вам нужно
Slide and hold the battery lock all the way to the left.
While holding the lock open, slide the battery up and out.
Slide and hold the back cover lock all the way to the right.
While holding the lock all the way to the right, slide the back cover down and lift the cover.
Slide the battery back into place.
Slide the battery lock to the right to secure the battery.
Replace the back cover.
While pushing the back cover upwards, slide the back cover lock to the left.
Make sure to keep your available data space at an optimal level to ensure that your device runs at a normal pace.
