Введение
This guide will assist you in removing the back panel of your computer so you can access its components.
Keep in mind that this is not a replacement guide, however it is a prerequisite guide to other replacement guides.
Please follow instructions as they appear.
Выберете то, что вам нужно
Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
Slide the panel towards you and lift it up to open and access the back of the computer.
Почти готово!
Финишная черта
