Введение
This guide explains how to remove the hard drive from the laptop.
Выберете то, что вам нужно
Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
Remove the remaining four 7.3 mm screws using the same screwdriver.
Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
3 участников успешно повторили данное руководство.
3 Комментариев
Which SSD is compatible with this computer?
Very nice its clear
