Введение
Use this guide to replace the battery in your HP ElitePad 900.
Выберете то, что вам нужно
Unscrew the two 2.8mm Phillips #000 screws near the power connector.
Use a suction cup to pull the display assembly up.
Several of the clips that hold the screen in appear to be spring loaded and magnetic. I theorize that the official replacement tool contains magnets that pushes those clips back toward the center of the screen, releasing them. I’m wondering if the same thing could be accomplished with the proper end of a bar magnet. I do know that if you lay the removed screen down on the 6 little screws that hold the battery in, you will have a devil of a time finding them stuck to one of the clips. At least the floor of the shop got a good sweeping. ;^)
Remove the six 2.2mm Phillips #000 screws securing the battery to the device.
13 участников успешно повторили данное руководство.
2 Комментариев
One way to remove screen assembly without a suction cup is to use a piece of duct tape folded onto to itself leaving a small amount of the adhesive portion exposed. This creates a little handle. You can then stick it to assembly and lift it out easily.
