Введение
There are 2 RAM slots in the 6930p Laptop. One is the expansion slot and accessible from the underside of the device, the other is the default location for factory installed RAM and is located under the keyboard. This guide focuses on the expansion slot
Запчасти
Никакие детали не требуются.
  1. Flip laptop over and locate the battery release button Push release button to the left to release battery and gently pull battery from the laptop Push release button to the left to release battery and gently pull battery from the laptop
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Locate the RAM expansion slot cover on the bottom of the laptop Loosen the PM2.0×5.0 captive screw and remove the cover.
    • Locate the RAM expansion slot cover on the bottom of the laptop
    • Loosen the PM2.0×5.0 captive screw and remove the cover.
  4. Install RAM module into the RAM slot on an angle of around 30 degrees Press the RAM module down with your fingers on each corner until it clicks into the 2 metal clips and is locked down
    • Install RAM module into the RAM slot on an angle of around 30 degrees
    • Press the RAM module down with your fingers on each corner until it clicks into the 2 metal clips and is locked down
    • Check to ensure the metal tabs are holding the RAM module down on both sides
    • Reinstall the RAM cover
Заключение
7 участников успешно повторили данное руководство.
Richdave
Участник с: 09.04.2010
28 967 Репутация
Автор 30 руководств
Команда
Master Techs Member of Master Techs
Community
280 членов
Автор 784 руководств
Комментариев: 4
What kind of RAM do you place in this slot?
I want to upgrade my notebook, maybe with some RAM from ebay, so, What should I buy?
Jan Cerenohorsky - Ответить
Also, is there already any RAM by default? What is the maximum capacity you can upgrade to?
Jan Cerenohorsky -
Yes under the Keyboard and the Max is 8GB DDR2 6400
dcliddle - Ответить
Can you add an 8GB DDR2 6400 to your laptop (HP6930p) without upgrading or changing the factory installed one? The label on the bottom of mine says C2D P8700 2.53 GHz 4GB.
Thanks for any help!
Brian Fenech - Ответить
Просмотр статистики:
За 24 часа: 2
За 7 дней: 12
За 30 дней: 59
За всё время: 11,787
