Введение
This guide demonstrates how to safely remove and replace a damaged or malfunctioning keyboard. Following these steps should ensure a simple replacement for a keyboard that has experienced a spill, is missing keys, or otherwise does not function correctly.
Выберете то, что вам нужно
Remove the two Phillips #0 screws securing the keyboard to the laptop.
Turn the laptop over and lift the display to reveal the keyboard.
4 tabs are located at the top of the keyboard, which lock it in place.
Pry and twist the spudger along the top of the keyboard until each tab is released.
Remove each of the three cables by gently pulling them from their respective connectors.
4 участников успешно повторили данное руководство.
Один комментарий
Good guide. Thanks!
But you missed step 1. Remove two screws that hold the keyboard in place
