Введение
Replace dead or dying battery to solve for laptop powering off right away or quickly when unplugged
Выберете то, что вам нужно
Slide the latch, to the right, away from the lock symbol.
Slide the cover away from the latch to remove it.
Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
The two latches should be pulled back, one of which is spring loaded and must be held in place in order to remove the battery.
26 участников успешно повторили данное руководство.
2 Комментариев
Where do I buy another battery and how long does it last on the laptop? 4hr or more?
