Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
If your PC is overheating, you may simply have to dust and get rid of lint off the devices fan and heatsink or replacing the fan and heatsink on your HP EliteBook 840 G1
  1. Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Slide the latch, to the right, away from the lock symbol.
    • Slide the cover away from the latch to remove it.
  2. Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
    • Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
    • The two latches should be pulled back, one of which is spring loaded and must be held in place in order to remove the battery.
  3. Battery should easily be lifted up and out.
    • Battery should easily be lifted up and out.
  4. Identify the RAM and the pull tabs that will be used in the next step.
    • Identify the RAM and the pull tabs that will be used in the next step.
    • Always use an anti-static wrist strap when working on a computer.
  5. Pull back the two tabs on either side of the RAM this will allow the RAM to be removed.
    • Pull back the two tabs on either side of the RAM this will allow the RAM to be removed.
    • When handling a memory module, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  6. Pull the RAM stick gently out and up once the tabs have been pulled to the side.
    • Pull the RAM stick gently out and up once the tabs have been pulled to the side.
  7. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  8. Loosen the four Phillips screws securing the hard drive. These screws will stay captive to the plastic hard drive bracket.
    • Loosen the four Phillips screws securing the hard drive.
    • These screws will stay captive to the plastic hard drive bracket.
  9. Grab the pull tab on the hard drives plastic casing and pull it out and to the side.
    • Grab the pull tab on the hard drives plastic casing and pull it out and to the side.
    • Make sure all screws have been properly loosened and are no longer connected at the bottom before doing this step.
    • Remove the 2.5" hard drive from the plastic bracket.
  10. In order to take out the fan and heatsink the plastic cover must first be taken off.
    • In order to take out the fan and heatsink the plastic cover must first be taken off.
    • Remove the eight 2 mm Phillips #1 screws.
  11. Remove SD card by sliding it out.
    • Remove SD card by sliding it out.
  12. Remove the thirteen 6 mm Torx T8 screws. Some screws have plastic covers over them that need to be pried out before the screws can be removed. Remove the single 7 mm Phillips #1 screw.
    • Remove the thirteen 6 mm Torx T8 screws.
    • Some screws have plastic covers over them that need to be pried out before the screws can be removed.
    • Remove the single 7 mm Phillips #1 screw.
    • Loosen the two Phillips #1 screws. These screws will remain captive to the device.
  13. Using the plastic opening tools, remove the plastic cover by beginning at one of the corners and prying it up. Using the plastic opening tools, remove the plastic cover by beginning at one of the corners and prying it up.
    • Using the plastic opening tools, remove the plastic cover by beginning at one of the corners and prying it up.
  14. Use the plastic opening tools to remove the keyboard, starting at one of the top corners. You need to lift the top side and then takeing it out  moving the keyboard towards the screen. Once the keyboard is removed, detach the ribbons connecting the keyboard to the laptop by prying the small tab and sliding the ribbon out.
    • Use the plastic opening tools to remove the keyboard, starting at one of the top corners. You need to lift the top side and then takeing it out moving the keyboard towards the screen.
    • Once the keyboard is removed, detach the ribbons connecting the keyboard to the laptop by prying the small tab and sliding the ribbon out.
  15. Loosen the six Phillips #1 screws. These will remain captive to the heatsink. Loosen the six Phillips #1 screws. These will remain captive to the heatsink.
    • Loosen the six Phillips #1 screws. These will remain captive to the heatsink.
  16. Use the plastic opening tools to remove the tape covering the wires connected from the fan  to the motherboard.
    • Use the plastic opening tools to remove the tape covering the wires connected from the fan to the motherboard.
    • Disconnect the fan by sliding the wire out.
  17. Remove the fan by lifting it up and sliding it out. Remove the heat sink by lifting it up and sliding it out.
    • Remove the fan by lifting it up and sliding it out.
    • Remove the heat sink by lifting it up and sliding it out.
Заключение
9 участников успешно повторили данное руководство.
Ashley Williams
Участник с: 27.08.2015
1 960 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 5-3, Blackwell Fall 2015 Участник USF Tampa, Team 5-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G3
4 членов
Автор 14 руководств
Один комментарий
Quality guide. Very logical. Thank you.
mediatrigg - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 16
За последние 7 дней: 70
За последние 30 дней: 305
За всё время: 11,616
