Введение
Use this guide when replacing the storage drive on a HP Elitebook 840 G7.
Storage drive is used to store data, files, and software programs that run on the computer.
Consider upgrading your storage drive if the current one is full or broken. A failing storage drive signs include: Failure to boot, slow performance, and file corruption.
Выберете то, что вам нужно
Use your Phillips # 1 screwdriver and remove the five 1.2mm screws from the back cover of the laptop
Removing the back cover to expose the hardware
Locate the M.2 storage stick and remove the 1.2 mm screw with a Phillips # 1 screwdriver
Один комментарий
Hi, it would be awesome if max length of drive is listed under "parts"
