Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Use this guide to remove the access panel on the bottom of the HP Elitebook 8460p. Removing the panel will grant access to the internal components for repair or replacement and needs to be completed before doing any work on the laptop.
  1. On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  2. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  3. Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
Заключение
Garrett Anderson
Участник с: 16.09.2019
1 325 Репутация
Автор 10 руководств
Команда
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 24
