Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Use this guide to replace the modem card. The modem card connects to the Firewire port on the back side of the HP Elitebook 8460p.
Not many computers today use Firewire, however, if you have the need to utilize the Firewire port on the back of your computer and the connection is not working, double check the condition of the modem card and the connection to the modem card inside the laptop.
Before opening the case, make sure you are grounded with an ESD strap to prevent electrostatic discharge from damaging other electrical components within the laptop.
To complete this guide, you will need a Phillips #0 screw driver and an ESD strap.
Запчасти
Детали не указаны.
  1. On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. Slide the battery away from the switches until it can be lifted away from the laptop.
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  5. Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  6. Attach an ESD strap to your wrist and to a ground. Using a Phillips #0 bit, remove the two 3.0 mm screws and set them off to the side side on a magnetic surface.
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, remove the two 3.0 mm screws and set them off to the side side on a magnetic surface.
  7. Push down on one corner of the sound card and lift it straight up. Push down on one corner of the sound card and lift it straight up.
    • Push down on one corner of the sound card and lift it straight up.
  8. Disconnect the wire plug by grasping the sound card in one hand and the wire in another and pulling them apart. Disconnect the wire plug by grasping the sound card in one hand and the wire in another and pulling them apart.
    • Disconnect the wire plug by grasping the sound card in one hand and the wire in another and pulling them apart.
Заключение
Garrett Anderson
Участник с: 16.09.2019
1 325 Репутация
Автор 10 руководств
Команда
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 27
За всё время: 132
