Введение
The 11.4V battery powering the hp envy is stored inside the bottom part of your laptop. To access the battery the laptop must be taken apart.
Выберете то, что вам нужно
Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
Remove the two cover tabs towards center of the bottom as there are screws underneath them.
Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
Separate the top cover by using a spudger to go around the sides freeing the inside latches.
Remove the three 3 mm screws from the battery using Phillips #0 screwdriver.
3 участников успешно повторили данное руководство.
