Введение
The brushless motor fan is designed to remove heat from the components inside your laptop and is crucial to prevent overheating. Overheating can cause permanent damage and possibly render the laptop useless.
Выберете то, что вам нужно
Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
Remove the two cover tabs towards center of the bottom as there are screws underneath them.
Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
Separate the top cover by using a spudger to go around the sides freeing the inside latches.
Remove the three 4.5 mm Phillips #0 screws holding the fan in place.
5 участников успешно повторили данное руководство.
