Введение
The 15.6" screen shows you what the computer is actually doing. Computers still work without a screen, you just can't see what they are doing.
Выберете то, что вам нужно
Remove the two screw covers located in the bottom corners of the screen and the 2.5 mm Phillips #0 screws underneath them.
Only after removing the two bottom corner screws in Step 1, separate the screen from the back using an opening tool.
3 участников успешно повторили данное руководство.
